Zanussi ZWF1221W
  • #48969
    spimps
    Doesn’t start after the button is pressed and after 30 seconds ish end light flashes,it seems the neutral from the door interlock has gone open circuit but it works occasionally,anyone encountered this before.
    Possible dry joint on pcb ?
    Cheers
    BG
    #298331
    TheSpinDoctor
    Re: Zanussi ZWF1221W
    How many flashes of the end LED do you get before the flashing pauses & restarts.
    Also, do you have the product number beginning 914?
    #298332
    spimps
    Will check the flashing lcd’s tomorrow,product no is 914215103(01)
    #298333
    spimps
    Am getting 4 falshes ie press the start button then end light flashes 4 times !
    BG
    #298334
    TheSpinDoctor
    Most likely just the door lock has failed but if you replace that & it is still the same, the triac that operates the lock has most likely blown as a result of the lock failing.
    #298335
    spimps
    Thanks for that,I see there are about three different door locks for this,the faulty one has a black body.
    #298336
    TheSpinDoctor
    Part numbers are:
    Door lock: 1260607039
    Control board (Configured): 973914215103016
    #298337
    spimps
    Gratias
