zanussi zwf1237 e80
  • #49386
    wilf
    washer showing E80 recirc pump completely burnt out. fitted new one and display still read E80 so cleared the code by holding start/pause and reset code cleared and machine now fills then goes straight to drain. I can skip to select spin and get motor action I’m thinking the boards gone west but would be gratefull for any other ideas.
    wilf
    #299724
    cab
    Re: zanussi zwf1237 e80
    If you have changed the pump the onlt things left are wiring and pcb for the E80 codes
    #299725
    lerch
    If circ pump go’s it normal takes out the pcb so check for marks etc.
    #299726
    This might interest you.
    zwd1472w
    Mike.
    #299727
    TheSpinDoctor
    It is the board, no question. When the coil on the pump goes, so does the triac on the board.
    #299728
    wilf
    thanks for all your help looks like BER!!
    wilf
    #299729
    Have a picture of the board I did, showing the AC switch concerned if you’re interested in trying to repair it. It’s labelled TYACS3 and is in one corner of the board, easy to find. Replacement component costs pennies from RS. If you send me your e-mail address I can send the pic. and a link to the spare.
    Mike.
