zanussi zwf14070
  • #62010
    scoobya1
    when I put the machine on spin, pump comes on for about 3 seconds then just stops. sometimes door light flashes sometimes it doesn,t. Any clues please
    #348396
    Re: zanussi zwf14070
    scoobya1 wrote:Any clues please
    What have you tested so far? Heater/Motor/Pressure Switch OK are they?
    If all appears to check out OK then your only option is to enter the diagnostics routine to find the last known error.
    #348397
    These cases are often to do with low insulation somewhere in the machine. As this is only a washer (is it not?) then favourite is motor – look for condensation on brush holders causing insulation at 500v to drop below 40 Meg.
    Mike.
