Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZWF14070W
- This topic has 10 replies, 3 voices, and was last updated 16 years, 4 months ago by
A1TEC.
November 27, 2009 at 8:58 pm #50518
A1TEC
ParticipantHad a quick look at this machine tonight, pump running regardless of program selected. No flashing lights or fault codes showing.
I have had a quick search through some of the recent posts to see if i could find some info relating to this fault.
So looking for some help on what to check.
cheers
John.
November 27, 2009 at 9:02 pm #305084Jonah
ParticipantRe: Zanussi ZWF14070W
Only advice John is to go through the diagnostics on the PCB, I do change a lot of Zanussi PCB’s but best to check first, if you have the TDS DVD it will tell you how to do diagnostics check HTH
November 27, 2009 at 9:07 pm #305085A1TEC
Thanks for the quick reply Dave, i don’t have the info to access the diagnostics as it’s not a common machine in my local area. 🙁
Would anyone be able to email me the info on how to access diagnostics.?
cheers
John.
November 27, 2009 at 9:16 pm #305086leavemetogetonwithit
Worth checking that draining properly – filter/sump. Maybe disconnect p/sw hose. Have you got a Connect a/c? Info is on Mediator. PM me if no.
Mike.November 27, 2009 at 9:19 pm #305087Jonah
As my local friend Mike says the filter is possible, but I guessed you probably checked that, have you got the PNC number and I will email you the service manual
November 27, 2009 at 9:25 pm #305088A1TEC
P.M sent Mike.
John.November 27, 2009 at 9:29 pm #305089A1TEC
Dave, i did not take a note of the pnc number 😳 i know i should have just incase. 😆
p.s feb 2008 was date of manufacture if that helps.
Filter was clear and pump spinning o.kJohn.
November 27, 2009 at 9:30 pm #305090Jonah
No worries, PCB probably the same type,PM me youre email address and I’ll send inf to you
November 27, 2009 at 9:44 pm #305091Jonah
Sending it now John, good luck 🙂
November 27, 2009 at 9:50 pm #305092A1TEC
Thanks very much for that Dave. 😀
Will post up the outcome at the start of the week.
Cheers
John.
November 30, 2009 at 3:19 pm #305093A1TEC
Just to update for Dave & Mike, machine sorted 😀
Thanks to Dave for the info on the diagnostics, it was just a case of clearing the last error info and away she went. 😉Cheers
John.
