Re: zanussi zwf14070w drum wont spin
the new gen zanussi’s are generally too young to need carbon replacements so far. even under heavy usage they should only be half worn.
first things first, drain your sump and check your fluff filter and pump for obstructions. this is covered in your instruction manual.
secondly, virtually all latest washers have out of balance controls which will prevent the washer from spinning laundry that cannot be spread evenly, and equally weighted around the drum, and therefore “times out” the appliance, therefore it will not drain, spin, or complete a cycle.
after clearing pump of any obstructions, replace filter, empty drum of all clothes, select the spin cycle only programme and press start. report back if the appliance still wont spin.
