Zanussi ZWF14070W Will not start wash
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF14070W Will not start wash
  • #80399
    starfire
    Hopefully someone can help, this is the issue:
    Put in washing, move dial to 40C, start/pause flashes normally, press this, wash light comes on but then door light also comes on – normally just the wash light comes on until the wash has finishes. Washer then never starts, just sits there, cannot open door.
    Have to reset by turning off at mains, then after a period of time can open the door.
    Any ideas or time for a new washer, its just over 6yrs old ?
    Thanks!
    #412674
    Re: Zanussi ZWF14070W Will not start wash
    Power off and then take a close look at the door interlock plug-in connector.
    #412675
    starfire
    Thanks for replying, is the interlock something I can easily access or would you recommend I simply call an engineer, or at this age look for a new machine (it does make quite a bit of noise now while spinning) ?
    #412676
    starfire wrote:it does make quite a bit of noise now while spinning) ?
    Not good news, it’s days numbered 🙁
    #412677
    starfire
    OK 🙁
    Checking the manual its actually normal for the wash and door lights to come on at the start of the program so not sure what the issue is, the machine just does not start washing.
    #412678
    Have you checked that interlock yet? I guess not so report back when you have.
    #412679
    starfire
    No I haven’t, is the interlock something I can easily access or would you recommend I simply call an engineer?
    #412680
    starfire wrote:No I haven’t, is the interlock something I can easily access or would you recommend I simply call an engineer?
    The interlock is accessed via unclipping the front door seal retaining ring. I have no idea as to your capabilities but we must assume those that ask the questions must have a fair degree of electro/mechanical knowledge. We cannot and will not give step by step instructions but instead give guidelines as to the best course of action to take.
    Call out a local guy if DIY is not for you of course. We may well have one listed in your area via our engineer search facility on the home page. 😀
    #412681
    starfire
    Think I will get an engineer, thanks for assistance.
