zanussi zwf1421w beeping and full of water!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi zwf1421w beeping and full of water!
  • #76162
    bois
    My Zanussi zwf1421w is stopping mid wash and beeping, always when it’s full of water!
    I have read another similar thread on this forum and done what was advised…..I’ve drained the machine and checked the filter is clear and checked the little wheel thingy (sorry I am really not good at this stuff lol!) inside the filter and it goes around fine, when I put the machine on a pump out programme the machine just makes noises like it’s trying to drain the water but can’t……is there anything else I can check?
    From everything I have read I am assuming it’s the drain pump???, is it possible for me to sort this myself or do I need an engineer? advice would be very much appreciated!
    #397430
    captaincaveman1
    Re: zanussi zwf1421w beeping and full of water!
    If the drain pump’s working then it has to be a blockage normally either in the sump hose {between the tub and pump manifold} or if its connected onto a sink spigot {Nozzle on the sink u bend} the you need to check around that area.
    #397431
    bois
    thanks for the reply captaincaveman…… Sorry to be slightly thick here but……I think I have only checked the filter, I opened a door on the bottom right of the front of the machine and drained the machine with the little hose then checked the filter next to it? how would I know if it’s the pump that’s broken?
    I’ll go and check the sump hose now 🙂
    #397432
    bois
    I’ve just checked the sump pipe and it all seems clear??
    #397433
    captaincaveman1
    Have you checked the drain hose and the sink spigot (if its connected to one ). If they are clear then it can only be the pump.
    #397434
    bois
    the drain hose and sink spigot are clear so I guess it needs a new pump! is it possible to order and fit a new pump myself or is it a professional only job?
    #397435
    bois
    I’ve just ordered a pump and my Father in law has agreed to fit it! so hopefully that will sort it 🙂
