Zanussi ZWF1421W will not start
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWF1421W will not start
  • #39845
    Bernie
    Zanussi ZWF1421W
    This machine is only 18 months old, selects program push start, pumps runs for a few seconds then stops all goes quiet for a minute or so then the end light come on, does not flash.
    Tried diagnostics program (start button and 1 other option button) only thing that happens is all the lights to the right (the vertical ones) flash on briefly then the start button light comes on, I did once get the diagnostics program to start, all the lights along the top came on in sequence as they should, water came in for 4/5 seconds, motor turned then the end light flashed six times, no other light came on so no fault code.
    I did test the heater and NTC all ok. Have inspected the module all looks ok.
    Do you think this is the board?
    If not what else could it be?
    Bernie
    #263807
    Re: Zanussi ZWF1421W will not start
    Bernie wrote:Do you think this is the board?
    The difficulty here Bernie is that it could well be the board at fault? I’m still worried about the end light flashing 6 times though? That does smack of heating element/NTC probs for sure. 😕
    If you are sure they are OK? (you could always plug a new one in briefly to try? 💡 ) Plus you need to check their connection to the module is OK of course before condemning it. 😯
    #263808
    timdowning
    Had a ZWF1631W yesterday with a bad connection on the circulation pump. It faulted as yours did. The point i’m trying to make is get yanking on those connections you might be suprised with the outcome. I know I was.
    #263809
    Bernie
    Thanks for the tips will go back tomorrow and let you know
    Thanks again
    Bernie
