zanussi ZWF1427W blowing main module .
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi ZWF1427W blowing main module .
  • #44511
    boyce
    HI any ideas anyone.Called on this machine & found it to have a blown module ,checked motor & obvious things all seemed ok so fitted a replacement .Guess what it went bang with motor disconnected .zanussi ZWF1427W blowing main module .Many thanks
    #281236
    Specialist01269
    Re: zanussi ZWF1427W blowing main module .
    What part of the boar went bang? i.e what does it drive?
    #281237
    Door interlock I expect?…Check the burnt PCB tracks and it will lead you to guilty component. 😉
    #281238
    boyce
    Has blown component r82 on the board & some tracking around that part also blackening around a grey oblong component with a letter M stamped on top of it maybe a capacitor .These components are around top off pcb when fitted on the side that has only 1 connector connected ,the other side of the board having the main connections .I have not got this model on my tds dvd must be newish.Hope You can help Cheers
    #281239
    Specialist01269
    With Martin on this, the only way to find what’s popping it is trace print on pcb to the edge connectors to see what it’s driving. circuit diagram doesn’t give component numbers & there are 2 different listed for this model: EWM1000+ & EWM2000
    #281240
    robbo1973
    done 6 or 7 of these now nd every time it has been the i/lock which has takenout main board then display board and on one the analogic pressure switch! there is a development near us with about 100 of these and all have came from here up to know.
    cheers chris
    #281241
    boyce
    Thanks , I will check when I call back to cx I’ll make sure I take a interlock with me , I will let you no how I get on
