Zanussi ZWF14280S
  • #53785
    CARLJONESDAR
    Going to look at this machine tomorrow, customer says machine sticks at the end of the program with 1 minute showing. Anyone got any ideas?
    #317217
    Re: Zanussi ZWF14280S
    Timed out either on drain or heat as a rule.
    #317218
    TheSpinDoctor
    Hi.
    Enter diagnostic to find last recorded fault code may give you some clues.
    #317219
    CARLJONESDAR
    I’ve been out to this machine today, the pump is ok and there is no blockage. Left machine on test and went back about an hour later, machine only had 9 mins left to run. At 6 mins it pumped out water and at 5 mins it started last rinse, didn’t start spin until only 1 min was left, only did a short spin then stopped, the door didn’t unlock and the time in the window went back to the start of the program and the green start button flashed. All this took about 25-30 mins. No recorded fault code as I cleared it a few weeks ago, then it was only showing door open. Any help on this would be great.
    #317220
    TheSpinDoctor wrote:Enter diagnostic to find last recorded fault code may give you some clues.
    Ditto on that idea……..have you done that I wonder? (you didn’t mention it earlier) 😕
    #317221
    CARLJONESDAR
    #317222
    pup
    check motor
    #317223
    CARLJONESDAR
    Motor tests ok
    #317224
    ….and the heater?
    #317225
    gandh1
    did you do the actual diagnostic test on the motor components, or just check continuity?
    #317226
    CARLJONESDAR
    Heater tests ok. Only tested the motor for earth and continuity. Have just downloaded the full service manual from connect. Will be going back to job next week to have another look. If anyone has any ideas befor i go back it would be great. Thanks
    #317227
    When you say you “tested motor for earth”, do you mean earth leakage? (i.e. insulation resistance.) What was result? ditto heater?
    Mike.
    #317228
    I know this thread refers to a Bosch machine but it looks interesting in this context.
    Mike.
