zanussi zwf14280w
  • #55892
    PINKY
    Evening guys,
    Have a ‘friend’ !!! yep the worst jobs always are :rolls: they have a zanussi zwf14280w. Apparently you set it up to start and after a few seconds of doing nothing it reverts back to ‘0’.
    Looking at it tomorrow, any ideas?
    Cheers in advance ………….Pinky
    #325481
    williemac
    Re: zanussi zwf14280w
    Do a diagnostic test page 3 of known error code
    #325482
    PINKY
    Have an ‘e43’ error code. triac fault although pcb looks ok. Is this common on these? is it a case of a new pcb?
    pnc 914522518
    Pinky
    #325483
    timdowning
    As you know E43 is door lock, wiring, or module faults.
    So it could just be the door lock. Saying that its always worth checking the length of the brushes as well.
    #325484
    maltheviking
    Anyone got to the bottom of the “E43” fault?
    I have a ZWF16581 which intermittently comes up with that fault code. 😥
    #325485
    chris211
    if it is a new machine it could be the door lock have been changing a lot recently mostly on machines under 1yr old there is a modified lock available,cant remeber the part number at the min though
    #325486
    It’s just the regular 1249675131 Interlock prob Mal. 😉
