Zanussi ZWF1431W Washing machine E30
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWF1431W Washing machine E30
  • #68386
    Latham63
    Machine starts on wash prog..drains, then when water should be taken,aborts and ends.Water supply and valves ok.Seems to be a control fault? E30 flashes up occasionaly.
    #370858
    Re: Zanussi ZWF1431W Washing machine E30
    Heater element up the swannie……..
    #370859
    Latham63
    Martin,tried a new heater(old one tested ok with mega),initially started to work,taking in water!Tested this twice,ok. Then when I thought all was well,started up again, prog aborted and E30 again! All I can think is module fault?
    #370860
    Criscold
    Have you tried diagnostics ? could be pressure switch or airtrap fault
    #370861
    Latham63
    Not sure how to do diagnostics on this machine? Never heard of air trap?
    #370862
    Criscold
    I think this should help – I think page 16 onwards for this model
    Colin
    #370863
    Latham63
    Thanks for diagnostic info.Have since taken machine to my workshop,plugged in and it works perfectly!!
    Now suspect the customers house electrical supply fault!
    #370864
    Latham63 wrote:Never heard of air trap?
    The pdf Chris posted between p27-p28 gives the E3* series of codes. Mostly p/sw related. So you may have a colourcatcher or suchlike causing an intermittent blockage around the pressure vessel (= air trap?) which IIRC is integral with the sump hose.
    If you haven’t already done so, take a good look in that sump hose, especially around the eco-ball. Analogic p/sws have also been known to give trouble.
    Incidentally, when you changed the element and it worked a couple of times, that might have been due to you disturbing the blockage.
    Mike.
