This machine works fine sometimes and others it will drain upon selecting a prog then about a minute later aborts from wash to drain, flashing E30(occasionally).If start & skip pressed simultaneously E34 appears.This could be a pressure switch fault apparently?
At point of ordering a new pressure switch.
Pressure switch defective;
Electrical current leak between heating element and ground; Heating element; Wiring defective;
Main board defective.
Water circuit
