Zanussi ZWF1432S dead.
  • #43505
    ENR 914521109-00
    Apparently worked perfectly on last wash, now if you switch on the mains neon illuminates then nothing, zilch, zippo.
    It will not enter diagnostics at all.
    No obvious signs of damage, brushes look OK etc.
    I’m guessing one pf the PCB’s has failed?
    Any previous on these?
    Re: Zanussi ZWF1432S dead.
    iadom wrote:Any previous on these?
    Sounds like the same problem as this? 🙁
    #277486
    Does sound very much like it, 😥 oh well, another one bites the dust.
    SL
    Try this trick.
    There is a blue lead running from the main pcb on the side to the front interface pcb.
    Disconnect this lead from both pcb’s and fit the end that was on the interface to the main pcb and vice versa.
    It may come back to life.
    These lead carry low voltage and are prone to poor connections.
    Our guys carry these as van stock.
    #277488
    Thanks for that, will give it a go. :tup:
    #277489
    sparepart
    Hi, I did post on the other zanussi thread that there are a couple of boards (new) on ebay for £15 each , did post part numbers , dunno if it helps ?
    Alan !
