Zanussi ZWF1437 time 155 and ERR
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWF1437 time 155 and ERR
  • #56469
    mvitorio
    For information.
    The display shows 155 constantly. If you switch the machine off or plug it out, when you plug it back in it still shows 155, If you push any button the display will show ERR for a few seconds also it will not let me enter diagnostics.
    Other similar posts have recommended disconnecting the connector block from the display board to the main board (the multi blue wire one), switching the machine on, then off, connector block back on. Usual safety measures.
    I can confirm that in my case this did the trick.
    #327535
    Re: Zanussi ZWF1437 time 155 and ERR
    ZWF 1630
    same fault
    same cure
    works a treat
    thanks
