Carbon brushs were gone on this machine. I replaced them and now customer says the machine goes through was but stops with 1 minute left. I ran it through test and it gave E35- tacko. Is this likely to be the fault as the machine washs and spins when I test it ??
E35 = Overflow on this model
Faults for E35
Water fill solenoid valve is defective; Leaks from water circuit on
pressure switch; Pressure switch defective; Wiring defective; Main
board defective. 😕
Cycle stops. Emergency drain
procedure. Drain pump continues to
operate (5 min. on, then 5 min. off,
etc.).
