Zanussi zwf14380
  • #80039
    AASWALES
    Hi the above machine will stop on a wash and the screen starts flashing 000 or so the customer tells me ? I have asked her to try a cold wash and it went through fine ,had a quick look this morning heater is ok , thermistor was not giving a reading on the meter but can’t be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure I was on it correctly as I only had the large meter with large probes ,
    Should we be getting some sort of error code with any heating problems eg thermistor?
    Alan
    #411443
    Seamy
    Re: Zanussi zwf14380
    Yes you’d imagine it should throw up an error code, did you go into diagnostics & check?
    NTC fault would be E70’s, heater E60’s, motor E50’s, door lock E40’s etc
    #411444
    AASWALES wrote: thermistor was not giving a reading on the meter but can’t be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure I was on it correctly as I only had the large meter with large probes ,
    I don’t know to what “large meter” you refer to? A Megger (insulation tester) to check for earth leakage on heaters etc. A multimeter (set on Kohms) to check the resistance of the the NTC. Incidentally, NTC’s rarely fail and when they do it is usually a leak to earth anyway so a Megger would at least show that up.
    #411445
    AASWALES
    Hi thanks for your reply’s , I did not have any info on me to go into the diagnostics but I will be going back on Monday to have a look
    Martin the meter I was talking about is and old multimeter used for automotive but the probes are too big for tiny pins on the thermistor , I have only had to replace one or two in my time so not confident that is the problem ,
    Cheers alan
