Zanussi ZWF14791W Program Timings Not Accurate
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF14791W Program Timings Not Accurate
  • #89231
    Camperdownfamily
    I have a Zanussi ZWF14791W washing machine. I’ve had it from new and it has never accurately predicted the running time of a program. It’s become a running joke in the house that the the washing machine has the mystical 1min left because in reality that could mean 10mins, 20mins, you just never know.
    In trying to diagnose a fault which eventually turned out to be the door lock recently, I watched the Super quick program through twice (believe it or not). It predicts that the program should take 45mins, but on both runs it filled with water and then washed the load until there was 4 mins left, then drained it, spun it, then at 1 min left it started rinsing, did two rinses and then spun the clothes taking a total of at least 70 mins.
    I’m just intrigued if this is a specific fault with my machine (it’s done it from new) or if this is a programming fault with the model range. It’s always seemed completely pointless having a timer which bears no earthly relation to the actual running times.
    Any thoughts?
    #440722
    timdowning
    Re: Zanussi ZWF14791W Program Timings Not Accurate
    Heater fault.
    #440723
    Camperdownfamily
    What could be wrong with the heater because it clearly works to some extent because the machine doesn’t just stop and doesn’t show any errors. Is it possible for a faulty heater element not to heat up enough so it heats the water slowly, but still to work?
    #440724
    No, Tim was referring to the possibility that the heater has a slight earth leak. That causes erroneous program timings and all sorts of crazy things.
    You’d be advised to check out the heater with an insulation tester as we do in the trade. No tester huh? Then change the heater. 😉
