Zanussi ZWF16070 – Not enough power!?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF16070 – Not enough power!?
  • #91895
    Oxford89
    Hello everyone!
    I got a Zanussi Essential ZWF16070W1 6 KG washing machine at home and I was just about to wash some clothes but it does not turn on properly. I can see the light turning on but nothing else happens.
    Here is the machine turned off
    Here when I turn it on again
    Does anyone have an idea what the problem is? Is there not enough power and I should try it again later? Or is there no solution to it?
    Let me know what you think!
    Thank you very much,
    Ox
    #449649
    Re: Zanussi ZWF16070 – Not enough power!?
    its not a power problem its more likely to be a faulty board
    Oxford89
    electrofix wrote:its not a power problem its more likely to be a faulty board
    Hi Dave,
    Thank you for your answer! Do you have any idea if there is a fix for this or will I need to replace the faulty board?
    Cheers!
    Dominic
    #449651
    don’t know without further investigation
    some external factors can affect the board to eliminate these you would need to disconnect all the wires to the board apart from the mains connection. if the board initializes ok then its prob something else if not its a replacement board
