Hi guys slight problem?
You can set everything on this machine programmes options etc!
Door will lock, When START button pressed keeps on flashing green? And will not run,
:rolls: any ideas?
Thanks Brian
door lock or wiring too it if you are lucky, and also a pcb if your not, as it will have taken out some of the tracks. but please check all componants for low resistance readings as they upset the microprosser and do strange things.
