hi, i put the machine through a test program and when it gets to the fault indication part it flashes the start button 4 times red then once white.
i disconnected heater still the same,
i checked the carbons ok also.
the door locks ok on test but when i try a program the start button just flashes and it wont start.
any ideas welcome.
Machine was tried to be started without door closed, or door interlock faulty. E41 is door lock, wiring or p.c.b faulty.
By the way start l.e.d should flash 4 times red & 1 green when showing fault codes, you sure you were reading it correctly ?
