Hi, I have an ongoing problem with above machine. Goes through cycle ok until it hits the spin and it just stops, if you drain and spin seperately it is fine – only happens now and again.
Brushes fine, heater fine, pump/waste fine, tacho in good shape.
Does anyone have the diags for this machine or any suggestions please.
Re: Zanussi zwf16070w – stops on spin cycle PNC 914521429
gadgetdad wrote:Thanks Martin, but surely this would show up earlier in the cycle ?
Possibly, true. But as it works on the spin only cycle and as the pressure system is not a function in that I figured it may be where the failing lies?
