Zanussi Zwf16070w1
  • #58427
    ray.t
    Hi I have been to this today the machine will only pump out.
    If you select any programme the machine will just pump and pump.
    I tried the machine on a rinse programme and it worked ok.
    Has anyone come across this before?
    Thanks,
    Ray.
    #334519
    Re: Zanussi Zwf16070w1
    Very common with modern lux. Try a search. Favourite is water not draining fully / p.sw. not reading empty so won’t start.
    Mike.
    #334520
    ray.t
    Hi I have put this machine through the diagnostic check and have come up with an error code of E69. I cant find that on the list of codes though, strange thing is though it seemng to be working now.
    Dont you just love this type of machine.
    Cheers,
    Ray
    #334521
    Seamy
    E69 = Heater open circuit, theres a thermo fuse in both legs of the heater.
    #334522
    ray.t
    Hi I tested it again it filled and washed ok pumped out fine and got stuck again just on drain.
    I think it is a problem with the pressure switch, I have ordered one and I will post with the outcome.
    Cheers,
    Ray
    #334523
    Simon46
    What was the outcome? Ive got one this morning?
    S.
