Zanussi ZWF1621W just stops
  • #64880
    Yet another mystery Zanussi fault. Symptoms: Select 40deg Eco wash, fills, tumbles and heats. At some point it simply stops and the Start/Pause LED just flashes. Turn machine off and select rinse-spin cycle then it works as normal, drains, rinses, spins and the turns off, no probs.
    I interrogated the ‘last error code’ and it flags up E23. (Pump triac, pump faulty, wiring faulty, circuit board faulty) and in the absence of not finding fault with other components I replaced the pump. (which was well worn anyway as it happens).
    Customer uses it straight after, exactly the same, stops mid cycle full of hot wet soapy with Start/Stop LED flashing. Turn it off, check last error (E23). WTF? :con:
    Customer well pi&&ed off and after looking at price of a circuit board, so am I. 👿
    #358363
    dave-m
    Re: Zanussi ZWF1621W just stops
    Not sure if this is much help Martin,
    But we’ve been thru similar before….
    viewtopic.php?f=3&t=64042
    #358364
    Thanks dave-m but no sorry, fault quiet different in this instance, thanks anyway. 🙂
    #358365
    jag-12
    Had a zwf1421 doing similar.Same error code.Sat watching it and just before it failed it did a short burst at spin speed then just sat doing nothing.
    Changed the motor and it has worked fine since.
    #358366
    deltra
    Re21W just stops
    water inlet valve???
