how do you delete the error code on these ? got it into test mode turn round to 6pm get code then turn to off , i turn one to right a get ele then does a test wash it seems but, reset with pause button but still just emptys on all programmes. am i doin something wrong ? help lads?
whilst you are reading error code you need to press the same 2 buttons used to access diagnostics that will clear code, then turn to off then on then off again it should then be back to normal after you have fixed the fault that is
the E50 doesnt really, that code relates generally to a motor fault or pcb pump/filter problems would normally be in the E20 range or E10 poor drainage if i remember right out of balance are usually EF codes
