zanussi zwf1632w
  • #47827
    fozzey
    hi
    does anybody have the fault codes for this machine
    the end light flashes 9 times and the acoustic signal sounds
    ive downloaded the user manual it just gives you the basic
    codes.
    any help would be gratefully appreciated
    cheers
    #294725
    fozzey
    Re: zanussi zwf1632w
    hi
    just refreshing this post on the hope somebody can help
    cheers
    #294726
    timdowning
    I think the nine flashes means the error is 90 something range of codes.
    When you say it just gives the basic codes what have you worked the basic code to be?
    #294727
    A1_Domestics
    The 90 errors are generally PCB communication related.
    Has the PCB been replaced or could you have possibly put the wires on wrong?
    Giving an accurate error code will help. Count the number of times the end-of-cycle LED flashes and also the start/Pause LED.
    So an error code of 35 would have EOC flash 3 times and SP twice.
