Zanussi ZWF1632W Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZWF1632W This topic has 3 replies, 3 voices, and was last updated 15 years, 3 months ago by Toni. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts December 17, 2010 at 5:16 pm #59653 ToniParticipant Hi When you put this machine on any programe, it just goes straight to pump. The end light flashes (4 flashes, Pause, 4 Flashes etc) Any help very much appreciated Toni December 17, 2010 at 6:37 pm #339060 gandh1Participant Re: Zanussi ZWF1632W connect mediator for zan service manual and zanussi diagnostics will be your friend… December 17, 2010 at 7:30 pm #339061 codletsParticipant Re: Zanussi ZWF1632W I had very same problem, different model number though. No error codes coming up either. I ended up ripping the machine to bits after swapping everything over to try and find the problem 😡 December 17, 2010 at 8:54 pm #339062 gandh1Participant Re: Zanussi ZWF1632W normally only external factor error codes are given out without diagnostics – low voltage, no water, no drainage… engineer error codes are only usually gleened after using the built in diagnostics. the one thing lux machines are good at are giving out error codes. sometimes one after another after another after another… but dont let that put you off. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
