Hi gents
this is my daughters washer select any prog but it stop on rinses could 1min or upto 1hour does this full of water & recycle pump on then stops no noise from any were just stops then fires up again later lcd display machine wife got it in for me if its not fixed for weekend no error codes appears
cheers alro
Pump faulty check filter & take off motor from filter to check if anything is fouling impellor. Also look at sump hose, i’ve had some with the ball sticking in the up posiition & not letting water down. Or rinse hold selected.
It should have an error code if it did’nt empty in time though.
