Zanussi ZWF16581W Pump
  • #59773
    richy
    Hi – no matter what programme is selected the pump is on constantly – any help appreciated please. Zanussi ZWF16581W
    Richy
    #339572
    Re: Zanussi ZWF16581W Pump
    The best way of figuring out where the problem lies is to set it through the diagnostics process. Then go to the 10th position to find out the last 3 alarm (error) codes it has (hopefully) memorised and go from there.:wink:
    Do let us know how you get on with that.:D
    #339573
    Seamy
    Check drain pump, filter & hoses as machine will run pump until zero water level is achieved. In service mode fill with water & drain, this can reset the electronic pressure switch sensing. If there’s been too much detergent in last wash, excess foam can give false reading of water in tub. You will only know when you check fault codes.
