Zanussi ZWF91483WH (914910401 02) Washing Machine Diagnostics…
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWF91483WH (914910401 02) Washing Machine Diagnostics…
  • #99624
    jontymox
    Good afternoon all,
    The above w/m is aborting wash cycles as follows: Quick Wash (30 Minute) – Press Start, Door Locks, Starts to Fill for a few seconds, then 1 Minute Remaining is Displayed, Door Unlocks, and 0 Displayed.
    When I tried a drain/spin cycle, start/pause led flashes, but will not remain lit, and door doesn’t lock.
    Not sure where to look, or if to suspect main board, and wonder if a Diagnostic Test would help?
    jonty
    #477120
    have you checked the heater ?
    have sent you service info
    jontymox
    Thanks Dave,
    Will revisit in the next couple of days, and let you know outcome.
    Best wishes,
    jonty
    #477122
    jontymox
    Good afternoon all,
    Well Dave, you’re right again!
    The element was causing the problem/s, and I’ve replaced it.
    It was severely corroded/damaged, and I wonder why it didn’t trip?
    Thanks again,
    jonty
