Zanussi ZWG 1120M
  • #70752
    Micky 32
    This machine only a year and a bit old. Doesn’t get much use as an old man living on his own owns it..
    Called to him this evening visiting him. Turned on his machine. The drum turns too fast each direction when washing and jumping and giving the error code E 62..
    I had no tools or meter to check anything. Is this the board or motor that’s failed?
    #378849
    captaincaveman1
    Re: Zanussi ZWG 1120M
    Motor tacho fault. But its cheap tack from china and not a true zanussi in the slightest. Throw away job.
    #378850
    Seamy
    Triac on PCB is faulty, change the PCB
    #378851
    captaincaveman1
    I know E62 says motor triac but I’ve found replacing the board is not always the answer its been the motor but seems as its just cheap cr4p in disgiuse as something which was once well built and respected either way throwing parts at it is false ecomnomy. (If its out the g’tee that is )
    #378852
    Seamy
    Would say i’ve done at least a hundred of these with E62, never had to replace a motor for an E62 fault, have had to replace many motors because of them breaking the mounting lugs off the tub & for wire broken to tacho.
    Triac could be replaced on P.C.B, not more than a quid for the part i’d think.. 💡
    #378853
    captaincaveman1
    Thats the other ohinese one the ZWG1000m that the motor breaks off and i carnt say ive done a hundred though so I guess there must be a high number of Gratton subsribers in your area LOL :mrgreen:
