Re: zanussi zwg 1140m no lights
If anything it went from a warmer area to a cooler part of the house, however it was exposed to a fair bit of dust etc as a result of the building works (which ended up somewhat more extensive than planned) which I’m sure hasn’t done it much good.
Having said that when I opened it up this morning the circuitry looked completely clean with no sign of any dust or water ingress even as far as the inner plastic part holding the pcb. No sign of obvious problems with the pcb either (burnt bits/blown capacitors etc). There was no ‘bad’ noise when it failed either. Simply switched off mid fill.
I guess what I’m wondering is: is it possible that a fault somewhere else in the machine could cause this complete lack of function or is this a pcb issue?
