Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWG 6165 not completing wash
- This topic has 8 replies, 2 voices, and was last updated 12 years, 5 months ago by
Rayw.
November 20, 2013 at 3:41 pm #78225
Rayw
ParticipantHi all
My Zanussi washing machine seems to go through a wash cycle ok- fills heats agitates rinses – but when it reaches the spin phase the drain pump is constantly on -it drains ok and spins, but then it seems to be stuck in a loop. The drain pump is on and it spins every few minutes, but wont end, even after an hour. The control knob on the front does not move, should it?Any ideas please
Thanks RayNovember 20, 2013 at 3:56 pm #404883Martin
ParticipantRe: Zanussi ZWG 6165 not completing wash
No the control knob doesn’t go round. Have you checked and cleaned the drain filter lately?
November 20, 2013 at 6:04 pm #404884Rayw
Thanks for your reply Martin. yes I’ve checked and cleaned the filter, and as I said, it drains ok, it doesn’t take long for it to empty.
November 20, 2013 at 6:11 pm #404885Martin
Well then all I would do is check all the components (motor, heater etc) especially their insulation potential. If all is well then it must be a faulty PCB.
November 20, 2013 at 7:23 pm #404886Rayw
Thanks again for your prompt reply Martin
The drain pump did get wet when we had a flood 2 weeks ago. I dried it out and it pumps out ok, but could this have affected the pcb? If the pcb needs replacing will the new one need programming?November 20, 2013 at 8:02 pm #404887Martin
If the fault was apparent since the flood then logically I would assume a connection. And the PCB can be purchased already configured should it be necessary to buy one.
November 20, 2013 at 8:44 pm #404888Rayw
I checked the pump insulation resistance after I dried it out, and it was ok, but if the pcb might be faulty then its not really worth buying a new one if I’m not absolutely certain that it is. It may be cheaper to replace the machine with a secondhand one.
Many thanks for your help.
RayNovember 20, 2013 at 8:49 pm #404889Martin
Well you do need to check the insulation of the heater and the motor as they can cause the PCB to go haywire anyway. Any spurious voltage can cause all manner of weird behaviour.
November 20, 2013 at 8:54 pm #404890Rayw
ok thanks I’ll check those tomorrow and let you know the result.
