Zanussi ZWG 7160P electric smell after spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWG 7160P electric smell after spin
  • #82688
    poly9
    I have recently noticed there is an ‘electric smell’ during and after spin. I have cleaned the filter and there are no bits in there. There is water under the drum, so don’t know if thats all supposed to drain away. Also when turning the drum, it is not silent, should there be a noise like a ‘clicking’. I have obviously turned the drum before but can’t remember if it was silent.
    I would be so grateful if anyone can help with this
    #420596
    Re: Zanussi ZWG 7160P electric smell after spin
    Sounds very much like a failing main motor. 🙁
    #420597
    poly9
    Thanks very much for your reply.
    Oh no – I was hoping it was something simple. Have you any idea how much this would cost to repair. Hard question I know. I’ve only had the machine about 3 years. 🙁
    #420598
    Have look inside the door to see if it says made in PRC or made in China, it it does then I wouldn’t waste any money it TBH. 😥
    #420599
    poly9
    Thanks again for reply. Can’t see anything with PRC or made in china, just the label with CE kitemark, serial number etc
    #420600
    If it was made in Italy it would say that on the rating plate, not sure about that model but a lot of recent Zanussi washers have been coming from China and they are rather poor.
    Removal and inspection of the main motor is the only way to be certain but if it makes a clicking noise as you spin the drum that is usually a sign of commutator failure inside the motor, accompanied most times by a smell and eventually a bang. :eeek:
    #420601
    Dependant on the product code (PNC number) the ZWG7160P was either made in Porcia Italy or Olawa in Poland. Nothing Chinese about this gem from the Planet Zanussi people. 😉
    #420602
    Thanks Martin , wasn’t sure but still sounds like a goosed motor, in fact it could even have a Chinese motor fitted. The most recent AEG(Zanussi) I wrote off had a Chinese inverter board in it, blown by a duff motor. :rolls:
