Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWG1120M – E62 code
- This topic has 5 replies, 2 voices, and was last updated 12 years, 12 months ago by
corimaman.
April 14, 2013 at 2:21 pm #75014
corimaman
ParticipantI found the machine had stopped mid cycle and was displaying E62 code. When I tried getting it going again the motor was working but it was intermittent as if there was a loose connection somewhere. I have had the back off and checked the big white connector to the motor and no sign of loose connection and the contacts are good. Tracing the loom up to the back of the control board I checked the connections there too. The load in the drum at the time the machine failed was towels and they may have been too heavy for what the machine can handle. Has anyone got any suggestions as to to what’s gone wrong?
April 14, 2013 at 2:41 pm #393599Specialist01269
ParticipantRe: Zanussi ZWG1120M – E62 code
Hi: If I remember correctly the E62 error on your machine shows that it’s detected an overheating problem during the wash cycle. It could be due to a faulty thermistor or possibly a faulty control PCB.
April 14, 2013 at 5:22 pm #393600corimaman
Hi Specialist01260 – thanks for your reply, are you able to direct me to the suspect thermistor and when you say it could be the control board, is that a case of replacing the whole board, the one on the back of the control fascia?
April 14, 2013 at 6:15 pm #393601Specialist01269
Hi Drew: Unfortunately the thermistor is built into the heating element & not available as a separate part, the element on these is pretty pricey. If you follow the wiring from the thermistor to the control board you can check the plug / socket connections for it, if it is a control pcb fault then unless you can get it repaired then the only option is replacement & I would’nt even like to think how much the pcb is. Your best option in the long run may be to call a local engineer to check the machine for you.
April 15, 2013 at 12:27 pm #393602corimaman
Hi – thanks for your advice but going back to the symptoms how does an overheating problem cause the motor to be intermittent? I know E62 is the code for overheating but could Zanussi have changed this?
April 15, 2013 at 12:43 pm #393603Specialist01269
Have you checked the motor brushes ?
