Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zanussi zwg6161
- This topic has 7 replies, 2 voices, and was last updated 9 years, 8 months ago by
wellsm122.
July 31, 2016 at 12:15 am #88930
wellsm122
Participantm/c stopped during cycle with water in m/c, set to drain but after a couple of seconds progamme ends, manually drained m/c, checked for blockage all ok, cleaned filter, switched m/c on and set to drain programme, heard pump for a couple of seconds the m/c started to fill
then stopped, reset and started drain programme again but after a couple of seconds programme ends, infact any programme ends after a couple of seconds. I suspect pressure switch, any help pleaseJuly 31, 2016 at 8:15 am #439798Gavin.allport
ParticipantRe: zanussi zwg6161
If it has a linear pressure switch you may have to reset it after manually draining the appliance.
Turn the machine off pour in 1.5 litres of water then put on a drain cycle. You might have to do this more than once as they can be temperamental
July 31, 2016 at 11:06 am #439799wellsm122
thanks Gavin, tried the reset but still the same fault drain pump noise for 1 or 2 seconds then starts to fill. whilst is was working on the machine I tested the drain pump, 238 ohm, is the ok or a little high, also measured the voltable on the connectors when on drain cycle, 1 or 2 seconds at 240v but the is all over the place, so would your recommend pump or pressure switch and anything else……..
cheersJuly 31, 2016 at 3:28 pm #439800Gavin.allport
Resistance sounds about right. If you put the machine on a spin cycle does it do the same? Have you checked the motor brushes? When the brushes go you can often get odd faults.
July 31, 2016 at 8:28 pm #439801wellsm122
yes on spin cycle fills then stops or with water in drum, programe ends after a few seconds.will check brushes tomorrow as working lates today
August 1, 2016 at 11:55 am #439802wellsm122
checked brushes both look ok, machine is only 18 months old,
prod 914906416, could it be the pcb, nbot worth changing or should i go for a cheaper part first……!August 1, 2016 at 4:44 pm #439803wellsm122
ran diagnostics and on every option the machine starts to fill with
water but does not post any error codesAugust 1, 2016 at 8:35 pm #439804Gavin.allport
If you’re in the diagnostic menu the last option will give you a fault code
