The above machine won’t respond to program settings it just displays zero and beeps three times, have had it draining once for a second it then stops beeps three times and reads zero on the display again.
I’m probably missing it but did look on the known effor codes but couldn’t see it
please help
John
Thanks Seamy I wish the display was showing either of those codes but it is definatelty zerro or O and three beeps.
Does anyone have the Service Manual for this model
Getting into diagnostics is same as other Zannies.
Fault codes are same, E10s are water fill faults, E20s are water drain/pump issues, E30s are pressure switch related, E40s are door problems, E50s motor, E60s heater, E70s NTC, E80s selector, E90 configuration.
