Zanussi ZWG7160P drum paddles
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWG7160P drum paddles
  • #84223
    tinfish
    Hello,
    can you actually replace the paddles on these new machines. You used to get access to the screws in the back of the paddles through the sump, but there’s no sump hose on them.
    Grant
    #425104
    Re: Zanussi ZWG drum paddles
    ZWG???? The model number of the machine in question would be helpful.
    #425105
    tinfish
    In this case it’s a ZWG7160P. I was being generic as I was assuming most of the newer ones with the 2 paddles and fluff filter will be the same construction.
    Grant
    #425106
    Re: Zanussi ZWG7160P drum paddles
    Generic don’t help much as the ZWG series stretches back 10 yrs. The ZWG7160P ‘blades’ (as they call them) are removed by removing the top counterweight. Once removed you have to drill (11mm drill bit) through centre of the two circles moulded in the tub to access the screws holding the blades in place.
    Then you’ve got to plug to holes with plugs (part no 50288048007) and silicone. 🙁
    Have fun!
    #425107
    From the manual….
    #425108
    tinfish
    Thanks for that, would never have thought to look under the counterweight.
    Grant
    #425109
    franz
    THAT IS MENTAL
