Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi zwh 7122j w/machine
- This topic has 15 replies, 5 voices, and was last updated 9 years, 5 months ago by
adv.
November 3, 2016 at 9:30 pm #89763
adv
Participantthis is doing my nut 😡 help, wasnt spinning or washing filled , brushes well down , fitted new ones . goes through wash spins for a bit , then stops door light flashes and goes back to original time . any clues lads , dont know why i bother . new zanussi stuff is garbage 😈
November 3, 2016 at 10:05 pm #442430electrofix
ModeratorRe: zanussi zwh 7122j w/machine
sound like the programmer is crashing.
have you tried another socket?
did you check last fault code ?Dave
November 3, 2016 at 10:13 pm #442431Martin
ParticipantRe: zanussi zwh 7122j w/machine
adv wrote:goes through wash spins for a bit
Not sure what you mean, it washes OK then? When does it spin or do you mean it goes tacho crazy during the wash?
November 3, 2016 at 10:20 pm #442432adv
no gradual spin as normal .. then just before main spin aborts . the carbons seem a bit noisy . wonder if its poor carbons , i wonder mmm? . and no there not in wrong way round :hazmat:
November 3, 2016 at 11:18 pm #442433electrofix
are brushes sparking ?
November 3, 2016 at 11:21 pm #442434adv
i think so sounds a bit like it . but most do till bed in ? a tiny bit not ?. i have cleaned amature
November 4, 2016 at 12:57 am #442435electrofix
you will have to look at the motor as it is trying to spin. if its sparking a lot you may have to remove the brushes and remove the high spots
excessive sparking can crash the programmerDave
November 4, 2016 at 1:02 am #442436adv
ok all give that a shot cheers
November 4, 2016 at 6:59 am #442437Simon46
Getting a lot of qualtex brushes with the wrong angle cut on the tip.
November 4, 2016 at 8:32 am #442438electrofix
Simon46 wrote:Getting a lot of qualtex brushes with the wrong angle cut on the tip.
was talking to the Qualtex rep about that only last week. He said he was unaware of the problem.
about time we started telling them as they cant fix what they dont knowDave
November 4, 2016 at 8:56 am #442439Simon46
Yes have had to resort to filing to a 45 degree angle as some of them are 30 degrees. Oddly some of the same part no are ok.
November 4, 2016 at 10:35 am #442440adv
😡 yep they are qualtex ones dont sound right at all
November 4, 2016 at 8:53 pm #442441adv
👿 well back to this today . with new set of carbons much better , chamfer on them and sounded a lot better ,. thought id cracked it , went through programme till half way through final spin . and done same . gutted ,fault code , is e 31 . but cant see how as fills and washes fine , blew down pressure switch and pipe , still same . gave up , pisst off 😕 even tried a new socket , but no diff ,as someone said , but cant see how that would make a diff any way mmm :con: should never have bothered, zanussi are garbage appliances now :death:
November 5, 2016 at 7:53 am #442442chezza
adv wrote:👿 well back to this today blew down pressure switch and pipe :death:
That’s something else you will need to replace then
November 5, 2016 at 8:42 am #442443Martin
adv wrote: zanussi are garbage appliances now :death:
They are fine as machines go. The one causing all your frustration is a conventional Zanussi, not new at all. I appreciate your getting angry over not finding the solution. Happens to us all every now and then.
In this case, yes you fitted suspect brushes but maybe, just maybe the motor was knackered anyway? A couple of blown segments perhaps? Who knows? We can only guess. It only takes one faulty component like that motor for the program to throw up all kinds of erroneous error codes. Sh- it happens but don’t lose faith in Zanussi’s, Hotpoint yes not Zanussi’s they are great money makers.
What I’ve learnt from this thread is that certain Qualtex brushes are duff. That’s a new one on me and I must keep my good eye on that in future :rolls:
