Zanussi ZWH7149P (914906683 00) W/M Constantly Drains
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWH7149P (914906683 00) W/M Constantly Drains
  • #85898
    jontymox
    Good morning,
    Could someone shed some light on a problem with a recently out of warrant washing machine?
    Essentially, on any wash or spin cycle the appliance will simply drain continuously for around one minute before pausing briefly, and then resume draining again.
    Water is not drawn, no wash or heat etc.
    I have checked the pressure switch, and system which is fine, and suspect the electronic control unit.
    I wonder if there is a test procedure, or re-set function for this appliance?
    Thank you,
    jonty
    #429770
    Re: Zanussi ZWH7149P (914906683 00) W/M Constantly Drains
    Try accessing last error code recorded (see below) then let us know what it is. PM me your email address and I can send you a copy of the service manual if you like. 💡
    #429771
    Seamy
    Blockage in pressure vessel/hose, pump housing/filter. Drain pump too weak, drain hose clogged etc, pressure sensor failure, highly unlikely p.c.b.
    Appliance has to read zero level before moving on.
    Power off and remove pressure hose from pressure sensor, then test on spin to see if it moves on after running drain pump.
    I’ve have replaced pumps on a few of these for similar problems, original pump has impeller which is angled off, when replaced with older type pump which has normal type impeller they seem to shift water out quicker.
