Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWI 71201 WA washing machine
- This topic has 11 replies, 3 voices, and was last updated 5 years ago by
Lori555.
April 7, 2021 at 12:30 pm #99383
Lori555
Participantmy machine stops with 8 minutes left on the timer, the timer then counts down to 1 minute but nothing happens. Error 21 was show once
There is water in the drum
I have checked the drain and also replaced the pump, but still have the same problem.
Not sure if I need to reset the machine, would be grateful for any adviceApril 7, 2021 at 12:46 pm #476118electrofix
Moderatorerror 21 is a drain issue
if you fill the machine on a rinse and then stop it and drain it. time it and see how long it takes till the pump changes note, when it draws air when the drum is empty
April 7, 2021 at 2:06 pm #476119Lori555
ParticipantThank you Dave, we have put the machine onto rinse and it has drained the machine and spun as it should.
However if I try another wash cycle it will again stop at 9 minutes (not 8) so the pump has done something but not sure where to go now. I appreciate any helpApril 7, 2021 at 6:50 pm #476120electrofix
Moderatorwell where i would go is the pressure switch
this switch uses air pressure to sense the water level. to do this it has a chamber at the bottom of the machine to trap air, this air is fed through a thin rubber hose to a switch at the top of the machine. Its possible for this chamber to get gunked up fooling the machine to think its still full
find this chamber and check all is clear but do not blow into the switch
April 8, 2021 at 8:30 am #476121Lori555
ParticipantUnfortunately still not working
April 8, 2021 at 8:31 am #476122Lori555
ParticipantI do appreciate all your help
April 8, 2021 at 8:50 am #476123electrofix
Moderatorok we know model i now need the pnc number off the model label
April 8, 2021 at 9:05 am #476124Lori555
ParticipantHi not sure if this is it, was on a label on the machine with the model number 914528134
April 8, 2021 at 10:31 am #476125electrofix
Moderatordoes the machine heat ?
April 8, 2021 at 5:20 pm #476126Lori555
ParticipantYes machine heats.
Just triad again and gets to 9 minutes and stops with water in the drum no spin, will count down and stop at 1 minute
if I put onto rinse mode it spins but doesn’t drain
If I put onto drain, machine will drain some of the water
I appreciate all the help you are giving meApril 8, 2021 at 5:43 pm #476127Lori555
ParticipantApprox 20 mins after drain cycle ends still showing 1 minute the drum goes round couple of times door open flashes, times goes to 9 and I can open the door
April 8, 2021 at 6:54 pm #476128John.G
ParticipantLori555 wrote:Unfortunately still not working
Pour a few litres of clean water into the machine, remove the hose from the pressure switch, blow gently downwards through the hose to prove clear then suck on it until you get water and immediately reconnect to the switch.
