Zanussi ZWI71201WA stops after one second – no fault code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWI71201WA stops after one second – no fault code
  • #103265
    alternativeGeorge
    When the start button is pressed, the door locks and the programme runs for a second then stops. The display briefly shows 0 then goes back to show the programme duration. There is no fault code and the led in the start button flashes. All programmes have the same result.
    what is the issue ?
    #492401
    first thing to check is motor brushes
    think its a brush motor but your model number brings up 8 varients so cant be certain without checking all or getting prod code
    alternativeGeorge
    Thanks for the suggestion Dave. I replaced the brushes although there was still some life left in the originals.
    The fault behaviour did not change. I’m going to try replacing the control board as there’s no obvious signs of damage anywhere else.
    #492403
    ok as a long shot disconnect the wires to the heater. insulate them and try the machine then
    alternativeGeorge
    Changed the control board which made no difference. Then following your suggestion started unplugging things in turn, since there’s not not much else to go wrong.
    It was after unplugging the water input solenoids that the fault went away. To my surprise, when I plugged them back in, the fault did not come back !
    There may be some weird wiring issue which has been cleared for the moment by the movement of the wiring loom ? Fingers crossed
    #492405
    andyjawa
    more likely to be a heater earth fault which very often will not trip a house trip swt board but should give you the fault as you describe
    #492406
    andyjawa
    PS. Disconnect the heater wires and try the machine on Rinses that way you should avoid the machine sensing the wires have been unplugged
    #492407
    You’re on the right track! Checking those components should help.
