zanussi zwn6120l prod 914904713/00
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi zwn6120l prod 914904713/00
  • #76980
    sce
    Here`s a good one!
    No go, but let me explain first. Turn to any programme and press start,the door locks, the pump comes on for 3 secs then sod all other than the lights are on. If however you disconnect the Welling made motor and remove the earth I then get the machine to fill, pump out.Reconnect the motor and 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time back to square one= no go. There is nothing wrong with the motor except it is very slightly to earth, affecting pcb perhaps? 20{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time I had it washing and spinning like a good `un i.e.you can get the machine to work ok with everything reconnected up including the motor earth-doing poor Andy`s head in this thing. Any suggestions- pcb or motor? Is this common? The machine is just over one years old-typical!!
    #400316
    aqualectric
    Re: zanussi zwn6120l prod 914904713/00
    Change the carbons anyway as dust from the old ones can track and cause issues. Blow out the motor with compressed air if you have the gear (don’t breathe the dust!!) I’ve changed half worn carbons in the past and the problem was solved.
    HTH,
    Steve.
    #400317
    sce
    Thanks will contact customer and see what she wants to do………it might be scrapped!
