Zanussi ZWT71201WA Overfilling
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWT71201WA Overfilling
  • #93842
    blawford
    As the title suggests, I have a Zanussi washer/dryer that overfills water past the top of the door and eventually water comes pouring out of the detergent drawer.
    I have looked into these symptoms and understood it was probably an issue with the pressure system. I taken the lid off the machine and removed the pipe from the pressure switch and I can blow down it, there are no blockages. I took a chance and ordered a new pressure switch as they weren’t too expensive, which hasn’t solved the issue.
    I’m not sure where to go next other than to replace the machine, which I would rather not do. Can anyone please advise of anything I can test or where they think the issue may lie?
    Thanks, any help greatly appreciated.
    #455707
    Re: Zanussi ZWT71201WA Overfilling
    are you getting any error codes ?
    have you looked carefully at the pressure hose for damage? a small pinhole is enough to lose the air and overfill
    if you pause the programme does the water stop flowing in ?
    blawford
    No, not getting any error codes.
    If I pause the programme it does stop filling immediately.
    Haven’t checked the hose, mainly because I’m not sure what the other end is connected to, whether it just pulls off and how I would go about reconnecting it.
    #455709
    item 114 connected to the sump hose is an air chamber
    that is where the hose goes and if after checking the hose for damage you find none the next check is to make sure this pressure bell is clear of sludge
    blawford
    electrofix wrote:item 114 connected to the sump hose is an air chamber
    Thanks for the suggestion, will give it a try.
    Any tips on how best to access it?
    #455711
    blawford
    OK, so I have another oddity.
    Been forced to handwash some clothes tonight, used the machine to spin them and then dry them. Spin works fine, then trying to dry them produces an ‘E10’ error code. After this, the clothes have gone from ‘damp’ after the spin cycle to ‘can wring them out’ wet during the drying cycle.
    Confused.
    #455712
    no it sort of goes with the other problems
    dryer uses cold water to condense steam
    there are 3 faults in the E10 range
    E11 Difficulties in water fill for washing
    E12 Difficulties in water fill for drying
    E13 Water leakage
