Zanussi ZWT71401WA (914606024) Washer/Dryer- Drying Problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWT71401WA (914606024) Washer/Dryer- Drying Problem
  • #86017
    jontymox
    Good afternoon,
    I’m struggling to put my finger on a drying fault on the above w/d.
    The customer complained of damp towels, even after over two hours drying, so I visited and checked the pump filter, heater, toc’s and operation of the drying cycle.
    I then put two damp towels in on a one hour drying cycle and monitored.
    The heater and fan are absolutely fine, as is the ducting into the drum.
    The heater also cycles on and off, and is turned off for the final twenty minutes or so.
    However, the towels were barely dryer than when they were added.
    Any help much appreciated!
    jonty
    #430045
    bazza500
    Re: Zanussi ZWT71401WA (914606024) Washer/Dryer- Drying Prob
    Choked condenser?
    #430046
    bazza500 wrote:Choked condenser?
    Jontymox says the ducting is fine Barry. Though he didn’t mention if the water was flowing through OK.
    #430047
    bazza500
    He said the ducting into the drum. I took that as being the heater ducting. I’m on about the condenser at the back.
    #430048
    bazza500 wrote: I’m on about the condenser at the back.
    I thought he meant the condenser. Surely he must have checked that, didn’t you Jontymox?
    #430049
    jontymox
    Good morning,
    The condenser itself is clear, so seems I should look at the water flow?
    jon
    #430050
    Yep, seems that way Jon. 😉
    #430051
    jontymox
    Thanks folks,
    I’ll thoroughly check the water flow etc, and let you know if that was the problem.
    jon
    p.s. Martin; sarcasm is the lowest form of wit. 😳
    #430052
    jontymox wrote:p.s. Martin; sarcasm is the lowest form of wit. 😳
    Sarcasm? You asked if you needed to check if water was flowing through the condenser.
    jontymox wrote:The condenser itself is clear, so it seems I should at the water flow?
    and my reply was….
    Martin wrote:Yep, seems that way Jon 😉
    You asked, I answered. That’s not sarcasm my friend. You have to pay extra for that if you want me to be sarcastic. 👿
    #430053
    jontymox
    Fair enough.
    Sorry for the confusion; I trust I haven’t offended you.
    jonty
    p.s. as a tight-fisted Yorkshireman, I refuse to pay extra for sarcasm.
    #430054
    jontymox wrote:Sorry for the confusion; I trust I haven’t offended you.
    Not in the least Jon. I too am a Yorkshireman though exiled down here Hampshire.
    You take care and if you need any help I will always strive to help where and when I can. As for the ‘Appliance Master’ tag, that was involuntarily put on me by one Kenneth Watt esq. the administrator of this fine web site. I have no influence over his droll sense of humour in giving me that title.
    All the best
    jontymox
    Well,
    I’m still struggling to cure this problem, and the Bosch dishwasher no heat fault.
    “back to the drawing board on both these problems.”
    jon
