zanussi zwx1506w
  • #30484
    tash
    hi.this washer 18 months old switches on ie mains light on…interlock locks but no display or response in any other way whatsoever..any advice appreciated..suspect power board control board or both..thanks
    #227362
    senseib
    Re: zanussi zwx1506w
    Check the edge connector on the facia board at the front of the machine, the thin connector strip often gives problems – try disconnecting gently squeeze connections together & then reconnect.
    Could solve the problem 🙂
    Brian.
