check the interface cable between main module and user interface tighten connectors gently wit pliers as they get loose causing strange problems and random error codes i.e E92 etc
The model number ZWX1600W is not recognised by TDS. 😕 Have you got the PNC number? If so, can you post it and I’ll see what I can find for you. 😉
