Zanussi ZWX1605 error codes
  • #49019
    Bernie
    Trying to find the error codes for Zanussi ZWX1605
    The machines start/pause LED flashes twice and the end LED flashes five times.
    I have looked in “KNOWN ERROR CODES” could not see anything there.
    Can anybody help please?
    Bernie
    #298512
    DentedPorsche
    Re: Zanussi ZWX1605 error codes
    Hiya,
    End of cycle is the first number, start/pause the 2nd.
    Error E52.
    E52: No signal from the motor tachymetric genetaror
    If I remember correctly the service manual gives, motor, wiring or pcb.
    HTH
    Brian 🙂
    #298513
    Bernie
    Many thanks for the info Brian
    Bernie
    #298514
    TheSpinDoctor
    Check the brushes. Usually, E52 is caused by worn brushes.
    #298515
    Bernie
    I had checked the brushes they were ok, had a second hand motor so tried that and all ok now thanks for the help
    Bernie
