Re: Zanussi zwx1605 w
from what you saying it does sound like a control board problem
just to clear thing up
when you press start do you hear the door lock go clunk
reason I ask is these door lock do fail but if you get no noise at all then its not normally the problem
also you should be able to get access to service mode ( assume you are holding buttons then turn machine on and hold for 4 secs or so )
you could try a long shot it does work on some zanussi machines
disconnect the ribbon cable from board to front display, plug machine in and turn it on for about 5 secs, turn it off again, then reconnect cable. turn back on and see what happen
dont hold a lot of hope on this one but its free so worth a try
as for J8-1 there should be 5v on this with respect to the board ground. but the diag shows that it is also neutral so you cant use earth as a base for this measurement but measure between J8-1 and J8-2
