Bugging me is this one,select any prog & all the correct lights for that prog light up as normal,press start/pause button & nowt all lites go out door int’lock clicks, try again & again & eventually it starts up & away you go,pause the prog & you are back to square one,try ,try again & off you go. Checked lead from control board to PCB & cleaned connections,no joy,tried door i/lock as last resort & just the same ,PCB? If so is it a config job or plug in & away you go? Prod # 914517270/00
Regards Chris…
